Saltar al contenido principal
why! N131WU Solid State Drive (SSD)
Qué necesitas
  1. why! N131WU Solid State Drive (SSD), Remove the Screws: paso 1, imagen 1 de 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Solid State Drive (SSD), Remove the Keyboard: paso 2, imagen 1 de 3 why! N131WU Solid State Drive (SSD), Remove the Keyboard: paso 2, imagen 2 de 3 why! N131WU Solid State Drive (SSD), Remove the Keyboard: paso 2, imagen 3 de 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Solid State Drive (SSD), Remove Keyboard Connections: paso 3, imagen 1 de 3 why! N131WU Solid State Drive (SSD), Remove Keyboard Connections: paso 3, imagen 2 de 3 why! N131WU Solid State Drive (SSD), Remove Keyboard Connections: paso 3, imagen 3 de 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Solid State Drive (SSD), Remove the upper screws: paso 4, imagen 1 de 2 why! N131WU Solid State Drive (SSD), Remove the upper screws: paso 4, imagen 2 de 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU Solid State Drive (SSD), Remove the SSD: paso 5, imagen 1 de 3 why! N131WU Solid State Drive (SSD), Remove the SSD: paso 5, imagen 2 de 3 why! N131WU Solid State Drive (SSD), Remove the SSD: paso 5, imagen 3 de 3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
Conclusión
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 421
