Saltar al contenido principal
why! N131WU RAM Replacement
Qué necesitas
  1. why! N131WU RAM Replacement, Remove the Screws: paso 1, imagen 1 de 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU RAM Replacement, Remove the Keyboard: paso 2, imagen 1 de 3 why! N131WU RAM Replacement, Remove the Keyboard: paso 2, imagen 2 de 3 why! N131WU RAM Replacement, Remove the Keyboard: paso 2, imagen 3 de 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU RAM Replacement, Remove Keyboard Connections: paso 3, imagen 1 de 3 why! N131WU RAM Replacement, Remove Keyboard Connections: paso 3, imagen 2 de 3 why! N131WU RAM Replacement, Remove Keyboard Connections: paso 3, imagen 3 de 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU RAM Replacement, Remove the upper screws: paso 4, imagen 1 de 2 why! N131WU RAM Replacement, Remove the upper screws: paso 4, imagen 2 de 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU RAM Replacement, RAM (Memory): paso 5, imagen 1 de 3 why! N131WU RAM Replacement, RAM (Memory): paso 5, imagen 2 de 3 why! N131WU RAM Replacement, RAM (Memory): paso 5, imagen 3 de 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
Conclusión
To reassemble your laptop, just follow the instructions in reverse.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,028 Reputación
244 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 302
