Saltar al contenido principal
why! N131WU Motherboard Replacement
Qué necesitas
  1. why! N131WU Motherboard Replacement, Remove the Screws: paso 1, imagen 1 de 1
    • Remove the case screws (red) and the keyboard screws (green).
    • Be sure not to lose these screws. You will need them to reassemble your laptop.
  2. why! N131WU Motherboard Replacement, Remove the Keyboard: paso 2, imagen 1 de 3 why! N131WU Motherboard Replacement, Remove the Keyboard: paso 2, imagen 2 de 3 why! N131WU Motherboard Replacement, Remove the Keyboard: paso 2, imagen 3 de 3
    • Using the hole provided under the case (see picture), push the keyboard out using a thin screwdriver or some other solid object.
    • Hold onto the keyboard as you push the keyboard so as not to damage the two cables still attached.
  3. why! N131WU Motherboard Replacement, Remove Keyboard Connections: paso 3, imagen 1 de 3 why! N131WU Motherboard Replacement, Remove Keyboard Connections: paso 3, imagen 2 de 3 why! N131WU Motherboard Replacement, Remove Keyboard Connections: paso 3, imagen 3 de 3
    • (Blue Cable) Push up on the thin black portion on the connector and gently pull out the blue ribbon cable until it comes out.
    • (Orange Cable) Remove the orange cable by sliding the gray part of the connector towards the screen, then gently pull on the ribbon cable.
  4. why! N131WU Motherboard Replacement, Remove the upper screws: paso 4, imagen 1 de 2 why! N131WU Motherboard Replacement, Remove the upper screws: paso 4, imagen 2 de 2
    • Unscrew the three screws that were under the keyboard. Be sure to hold onto these.
    • After these are removed, you can now remove the lower part of the case from the rest of the computer.
  5. why! N131WU Motherboard Replacement, Remove the SSD: paso 5, imagen 1 de 3 why! N131WU Motherboard Replacement, Remove the SSD: paso 5, imagen 2 de 3 why! N131WU Motherboard Replacement, Remove the SSD: paso 5, imagen 3 de 3
    • Remove the screw holding in the ssd.
    • Carefully remove the SSD from the connector.
  6. why! N131WU Motherboard Replacement, RAM (Memory): paso 6, imagen 1 de 3 why! N131WU Motherboard Replacement, RAM (Memory): paso 6, imagen 2 de 3 why! N131WU Motherboard Replacement, RAM (Memory): paso 6, imagen 3 de 3
    • Gently pull outwards on the clips to free the RAM stick.
    • Remove the RAM Stick from its slot.
  7. why! N131WU Motherboard Replacement, Battery: paso 7, imagen 1 de 2 why! N131WU Motherboard Replacement, Battery: paso 7, imagen 2 de 2
    • Remove the five Phillips screws securing the battery.
    • Unplug the power connector and lift the battery out in the direction of the arrows to remove it.
  8. why! N131WU Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 why! N131WU Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 why! N131WU Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Lift the retaining latch and unplug the ZIF cable found under the keyboard.
    • Disconnect the nine marked cables as detailed in the following steps.
    • Remove the four screws securing the motherboard to the case.
  9. why! N131WU Motherboard Replacement, ZIF Connectors: paso 9, imagen 1 de 3 why! N131WU Motherboard Replacement, ZIF Connectors: paso 9, imagen 2 de 3 why! N131WU Motherboard Replacement, ZIF Connectors: paso 9, imagen 3 de 3
    • The cables with the blue reinforcing tabs are ZIF connectors that require you to lift the retaining lever before removing the cable.
  10. why! N131WU Motherboard Replacement, SATA Cable: paso 10, imagen 1 de 3 why! N131WU Motherboard Replacement, SATA Cable: paso 10, imagen 2 de 3 why! N131WU Motherboard Replacement, SATA Cable: paso 10, imagen 3 de 3
    • Remove the SATA3 cable from the motherboard after disconnecting it.
  11. why! N131WU Motherboard Replacement, Motherboard (continued): paso 11, imagen 1 de 2 why! N131WU Motherboard Replacement, Motherboard (continued): paso 11, imagen 2 de 2
    • Don't forget to remove these cables.
  12. why! N131WU Motherboard Replacement, Display Connector: paso 12, imagen 1 de 2 why! N131WU Motherboard Replacement, Display Connector: paso 12, imagen 2 de 2
    • Note: The original instructions call for inserting your thumbnail firmly under the base of the display connector
    • However, the proper way to remove the display connector is to grasp the plastic strap on top of the connector and use it to pull the connector straight up.
  13. why! N131WU Motherboard Replacement, Remove the Motherboard: paso 13, imagen 1 de 3 why! N131WU Motherboard Replacement, Remove the Motherboard: paso 13, imagen 2 de 3 why! N131WU Motherboard Replacement, Remove the Motherboard: paso 13, imagen 3 de 3
    • Once the screws have been removed, carefully lift the motherboard from the end indicated by the arrows.
    • Remember to disconnect the cables near the fan.
  14. why! N131WU Motherboard Replacement, Motherboard (continued): paso 14, imagen 1 de 1
    • The motherboard has been successfully removed.
Conclusión
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Felice Suglia
Miembro Desde 06/15/13
29,055 Reputación
245 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 15
Todo El Tiempo: 201
