Saltar al contenido principal
uAttend bn6000 Screen Replacement
Qué necesitas
  1. uAttend bn6000 Screen Replacement, Disassembly: paso 1, imagen 1 de 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Screen Replacement: paso 2, imagen 1 de 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Screen Replacement, Screen: paso 3, imagen 1 de 2 uAttend bn6000 Screen Replacement, Screen: paso 3, imagen 2 de 2
    • Remove the four 10mm PH #2 screws from the screen assembly, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
    • Remove the screen assembly from the housing by pulling the screen up and away from the housing.
  4. uAttend bn6000 Screen Replacement: paso 4, imagen 1 de 3 uAttend bn6000 Screen Replacement: paso 4, imagen 2 de 3 uAttend bn6000 Screen Replacement: paso 4, imagen 3 de 3
    • Disconnect the ZIF connector, by using the plastic opening tool to lift up on the small locking flap. Then pull the ribbon up and away, out of the connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 315
