Saltar al contenido principal
uAttend bn6000 Keyboard Replacement
Qué necesitas
  1. uAttend bn6000 Keyboard Replacement, Disassembly: paso 1, imagen 1 de 1
    • Make sure to unplug the device before starting.
    • Flip the device over.
    • Remove the four 10mm PH #2 screws by rotating the screwdriver counterclockwise, removing the screw from the housing completely.
  2. uAttend bn6000 Keyboard Replacement: paso 2, imagen 1 de 1
    • Separate the two cover pieces carefully by pulling apart the two cover pieces away from each other.
  3. uAttend bn6000 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 2 uAttend bn6000 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • Remove the five 7mm PH #1 screws from the back of the keypad, by rotating the screw driver counter clockwise, removing the screw from the housing completely.
  4. uAttend bn6000 Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the bundled cable connector from the keyboard by pulling the cable away from the connector in the same direction as the individual wires are running.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 230
