Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Make sure the computer is unplugged and turned off before you start this procedure. Look on the bottom of the computer. Locate the 2 screws. (Picture 1) Using the Phillips 00 Screwdriver, unscrew both screws, and remove the bottom cover. The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
  • Make sure the computer is unplugged and turned off before you start this procedure.
  • Look on the bottom of the computer. Locate the 2 screws. (Picture 1)
  • Using the Phillips 00 Screwdriver, unscrew both screws, and remove the bottom cover. The bottom cover can be hard to pull off, so you may need to pry it off with a pry tool.
Insertar traducción aquí
