Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 2
Use the Phillips #0 Screwdriver to remove the two 4mm screws that are holding the SATA connector in place. Use the Phillips #0 Screwdriver to remove the two 4mm screws that are holding the SATA connector in place. Use the Phillips #0 Screwdriver to remove the two 4mm screws that are holding the SATA connector in place.
  • Use the Phillips #0 Screwdriver to remove the two 4mm screws that are holding the SATA connector in place.
Insertar traducción aquí
