Saltar al contenido principal
Inglés
Español
Paso 2
Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened. Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
Open the phone
  • Use the Pentaloble screwdriver to remove the charging port screws. Heating the phone with a heat gun will the phone easily to be opened.
Use el destornillador Pentalobe para quitar los tornillos del puerto de carga. Calentar el teléfono con una pistola de calor hará que el teléfono se abra fácilmente.
