Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 5
Paso 5
Place the motherboard on a clean, flat surface. Preheat your soldering iron. The Ethernet  port has fourteen points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the Ethernet port away from the board.
  • Place the motherboard on a clean, flat surface.
  • Preheat your soldering iron. The Ethernet port has fourteen points of connection to the motherboard (pictured below). Using your soldering iron, apply heat to each solder joint in turn while pulling the Ethernet port away from the board.
  • Soldering irons can reach temperatures of over 500 degrees. Watch your fingers!
  • For more information on soldering refer to How to Solder and Desolder Connections
Insertar traducción aquí
