Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Make sure the batteries are removed before attempting disassembly. Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws. Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
  • Make sure the batteries are removed before attempting disassembly.
  • Using your Phillips #1 screwdriver, remove the four visible 12.5mm screws.
  • Next, either peel up the longer of the two stickers or punch a hole with the tip of your screwdriver to access the fifth 12.5mm screw.
Insertar traducción aquí
