Saltar al contenido principal
Inglés
Español
Paso 6
Move the stationary probe to the ring terminal and repeat the previous procedure to identify the ring connector. The remaining connector corresponds to the sleeve. In this case, it is the longest connector. Slide the plastic sleeve over the headphone cable. Make sure that it is installed with the larger opening to the wire end.
  • Move the stationary probe to the ring terminal and repeat the previous procedure to identify the ring connector.
  • The remaining connector corresponds to the sleeve. In this case, it is the longest connector.
  • Slide the plastic sleeve over the headphone cable. Make sure that it is installed with the larger opening to the wire end.
  • To assist with soldering the small wires, a tool like this third hand is a big help, but not a necessity.
Insertar traducción aquí
