Saltar al contenido principal
Inglés
Español
Paso 5
Here is the replacement 3.5mm TRS plug. TRS stands for tip-ring-sleeve, and is the standard connector for audio jacks. The bottom of the jack has three connectors that each correspond to the tip, ring, or sleeve.
  • Here is the replacement 3.5mm TRS plug.
  • TRS stands for tip-ring-sleeve, and is the standard connector for audio jacks.
  • The bottom of the jack has three connectors that each correspond to the tip, ring, or sleeve.
  • With one probe constantly on the tip of the jack, probe the three connectors with a multimeter until you have continuity; this is your tip connector.
Insertar traducción aquí
