Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 7
Continue cutting through the adhesive on the top and right sides of the phone. The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive. The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive.
  • Continue cutting through the adhesive on the top and right sides of the phone.
  • The proximity sensor, earpiece speaker, and front-facing camera are all located along the top edge of the phone, but are housed beneath the display unit. You shouldn't come into contact with any of them as you insert your pick to cut the adhesive.
Continúa cortando el adhesivo en el lado superior y lado derecho del teléfono.
El sensor de proximidad, el altavoz auricular y la cámara frontal están todos ubicados a lo largo del borde superior del teléfono, pero se albergan por debajo de la unidad de pantalla. No debes entrar en contacto con ninguno de ellos al insertar la púa para cortar el adhesivo.
