Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Paso 3
In the following steps you will be cutting through the adhesive around the edge of the display assembly. Refer to the second and third images and familiarize yourself with the width of the adhesive around edges of the display. If you plan to re-use the display assembly, be particularly careful as you cut the adhesive on the sides of the phone. Don't insert your tool more than 2 mm into the phone, and angle it down (away from the display assembly) as much as possible.
  • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
  • Refer to the second and third images and familiarize yourself with the width of the adhesive around edges of the display.
  • If you plan to re-use the display assembly, be particularly careful as you cut the adhesive on the sides of the phone. Don't insert your tool more than 2 mm into the phone, and angle it down (away from the display assembly) as much as possible.
En los siguientes pasos vas a cortar el adhesivo alrededor del borde del ensamblaje de pantalla.
Observa la imagen segunda y la tercera y familiarizate con el ancho del adhesivo alrededor de los bordes de la pantalla.
Si planificas volver a usar el ensamblaje de pantalla, ten especial cuidado cuando cortes el adhesivo en los lados del teléfono. No insertes tu herramienta más de 2 mm dentro del teléfono e inclínala hacia abajo (lejos del ensamblaje de pantalla) lo más que sea posible.
