Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Now that the cover is removed, use the #1 Philips screwdriver bit to remove the four, 3mm screws located at each corner of the screen. To keep from losing the screws it is best to place them o a electronics rated magnetic work pad.  If you do not have access to such a pad a plastic bottle cap works just fine.
  • Now that the cover is removed, use the #1 Philips screwdriver bit to remove the four, 3mm screws located at each corner of the screen.
  • To keep from losing the screws it is best to place them o a electronics rated magnetic work pad. If you do not have access to such a pad a plastic bottle cap works just fine.
Insertar traducción aquí
