Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 4 guías que incluyan este paso.
Inglés
Español
Paso 6
Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame. It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame. It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
  • Hold the outer watch case steady and push against the bottom of the inner assembly to remove the inner assembly from the frame.
  • It should not take much force to push the inner assembly out of the watch frame. If it seems stuck, make sure that you've rotated the inner assembly far enough to release it from the frame.
Sostén la caja exterior del reloj con firmeza y empuja contra el fondo del ensamblaje interior para sacar el ensamblaje interior del marco.
No debería hacer falta mucha fuerza para empujar el ensamblaje interno fuera del marco del reloj. Si parece atascado, asegúrate de haber girado el ensamblaje interno lo suficiente para liberarlo del marco.
