Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 6
Remove the 13 screws (circled in yellow) using a phillips screwdriver. Be sure to keep track of which screws go into which hole.
  • Remove the 13 screws (circled in yellow) using a phillips screwdriver.
  • Be sure to keep track of which screws go into which hole.
  • Remove the one screw (circled in red) that has a Torx head.
  • The Torx screw is hidden under a rubber gasket. Carefully, lift up the gasket without damaging it to access this screw.
Insertar traducción aquí
