Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 6 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 6
Paso 6
Use the nylon spudger to lift  the white tab by 90 degrees. Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers. Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
  • Use the nylon spudger to lift the white tab by 90 degrees.
  • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
Insertar traducción aquí
