Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
Once all of the adhesive is freed from under the logic board/battery assembly, lift the assembly up from the side and carefully rotate it over to access the underside of the battery. The logic board is still attached to the rear case. Do not try to completely separate the assembly, or you will rip this ribbon cable. The logic board is still attached to the rear case. Do not try to completely separate the assembly, or you will rip this ribbon cable.
  • Once all of the adhesive is freed from under the logic board/battery assembly, lift the assembly up from the side and carefully rotate it over to access the underside of the battery.
  • The logic board is still attached to the rear case. Do not try to completely separate the assembly, or you will rip this ribbon cable.
Insertar traducción aquí
