Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 2
In the next few steps, you will loosen the adhesive from underneath the battery, the logic board, and the frame under the battery. Do this slowly, carefully, and evenly. Take care not to puncture the battery or bend the logic board. Use a plastic opening tool to pry up the adhesive around the three exposed edges of the battery. Do not try to pry the battery out, just start loosening the adhesive.
  • In the next few steps, you will loosen the adhesive from underneath the battery, the logic board, and the frame under the battery. Do this slowly, carefully, and evenly. Take care not to puncture the battery or bend the logic board.
  • Use a plastic opening tool to pry up the adhesive around the three exposed edges of the battery.
  • Do not try to pry the battery out, just start loosening the adhesive.
Insertar traducción aquí
