Saltar al contenido principal
Inglés
Español
Traduciendo paso 14
Paso 14
The Huawei Mate 9 earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
Final Thoughts
  • The Huawei Mate 9 earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • Most of the components—like both camera units, the loudspeaker, and the USB board—can be replaced. Even the proximity sensor and the NFC antenna are modular.
  • Despite the annoying hexalobe screws, the Mate 9 comes with only a few standard Phillips screws on the inside.
  • The battery is trapped behind some flex cables and is glued tightly into place, but still can be swapped out when its power starts to fade away.
  • Although we are happy to find a headphone jack, it is soldered to the board and calls for special soldering skills if it should fail.
  • Replacing a broken display, one of the most common repairs, will be one of the most difficult ones on this phablet.
Insertar traducción aquí
