Saltar al contenido principal
Inglés
Español
Paso 4
Due to the construction of the Touch, the digitizer cable cannot be disconnected until the logic board is removed. Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable. The display data cable is very short and is connected to the logic board near the top of the front panel assembly. If it does not become disconnected while freeing the top edge of the front panel assembly, be sure to disconnect it with a plastic opening tool before rotating the front panel assembly out of the Touch.
  • Due to the construction of the Touch, the digitizer cable cannot be disconnected until the logic board is removed. Use extreme caution when handling the front panel assembly, as it is attached to the rest of the Touch by the very delicate digitizer cable.
  • The display data cable is very short and is connected to the logic board near the top of the front panel assembly. If it does not become disconnected while freeing the top edge of the front panel assembly, be sure to disconnect it with a plastic opening tool before rotating the front panel assembly out of the Touch.
  • Carefully pull the top of the front panel assembly away from the adhesive holding it to the Touch, minding the short digitizer cable connecting the two components.
Debido a la construcción del Touch, el cable del digitalizador no puede desconectarse hasta que se retire la placa lógica. Tenga mucho cuidado al manipular el conjunto del panel frontal, ya que está unido al resto del Touch por el cable del digitalizador muy delicado.
El cable de datos de la pantalla es muy corto y está conectado a la placa lógica cerca de la parte superior del conjunto del panel frontal. Asegúrese de desconectarlo con una herramienta de apertura de plástico antes de girar el conjunto del panel frontal fuera del Touch.
Tire con cuidado de la parte superior del ensamblaje del panel frontal alejándolo del adhesivo que lo sujeta al tacto, teniendo en cuenta el corto cable del digitalizador que conecta los dos componentes.
