Saltar al contenido principal
Inglés
Español
Paso 3
When there is enough room to grab the bottom edge of the front panel, lift the front panel away from the body of the Touch to peel up the adhesive along its left and right edges.
  • When there is enough room to grab the bottom edge of the front panel, lift the front panel away from the body of the Touch to peel up the adhesive along its left and right edges.
  • If the adhesive is too difficult to separate, use a heat gun to soften it before proceeding.
Cuando haya suficiente espacio para agarrar el borde inferior del panel frontal, levante el panel frontal del cuerpo del Touch para quitar el adhesivo a lo largo de sus bordes izquierdo y derecho.
Si el adhesivo es demasiado difícil de separar, utilice una pistola de calor para suavizarla antes de proceder.
