Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 3
Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly. Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive. Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
  • Additionally, do not press down on the battery as you pull the strips. Pressing on the battery creates pressure points that can snag and break the adhesive.
  • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
  • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
  • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Intenta de mantener las tiras planas y desarrugadas durante este procedimiento; las tiras arrugadas se pegarán juntas y se romperán en vez de salir limpiamente.
Adicionalmente, no presiones la batería al jalar de las tiras. Presionar las baterías crea puntos de presión que pueden golpear y romper la adhesiva.
Lentamente jala una de las tiras de adhesivo de batería hacia el inferior del iPhone.
Jala constantemente, manteniendo una tension constante en la tira mientras se desliza entre la batería y la caja trasera. Para mejores resultados, jala la tira a un ángulo bajo sin golpear ninguno de los otros componentes del iPhone.
La tira se estirara varias veces su tamaño original. Continua tirando, agarrando la tira cerca de la batería si es necesario, hasta que la tira entera sea liberada.
Si las lengüetas de adhesivo de la batería se rompen durante el proceso de extracción, usa tus dedos o pinzas despuntadas para extraer el resto del largo del adhesivo y continúa jalando.
Si una de las tiras adhesivas se rompen por debajo de la batería y no se pueden sacar, intenta remover las tiras restantes y luego procede como se instruye abajo.
