Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 12
Here it is, the secret to the squeeze—half of the pair of sensors responsible for detecting when you squeeze the edge of your Pixel 2 XL. The sensor consists of a flexible printed circuit board wrapped around both sides of a line of steel chunks, with strain gauges bridging the gaps between the metal bits. Strain gauges are deformation-sensitive resistors, that slightly change their resistance when stretched or squished.
  • Here it is, the secret to the squeeze—half of the pair of sensors responsible for detecting when you squeeze the edge of your Pixel 2 XL.
  • The sensor consists of a flexible printed circuit board wrapped around both sides of a line of steel chunks, with strain gauges bridging the gaps between the metal bits.
  • Strain gauges are deformation-sensitive resistors, that slightly change their resistance when stretched or squished.
  • Having two rows of strain gauges separated by spacers should give this sensor higher resolution than a single strip of gauges would, allowing it to detect even the slightest of deflections.
  • As you squeeze, the outer row of gauges should be shortened, while the inner row is lengthened. This gives the Pixel software a larger absolute deflection to detect and measure to trigger the feature.
Aquí está el secreto de la mitad apretada del par de sensores responsables de detectar cuándo aprietas el borde de tu Pixel 2 XL.
El sensor consiste en una placa de circuito impreso flexible enrollada alrededor de ambos lados de una línea de trozos de acero, con medidores de tensión que cierran la brecha entre las brocas metálicas.
Los medidores de tensión son resistencias sensibles a la deformación, que cambian ligeramente su resistencia cuando se estiran o aplastan.
Tener dos filas de medidores de tensión separados por separadores debe dar a este sensor una resolución más alta que una sola tira de medidores, permitiéndole detectar incluso la más mínima desviación.
A medida que aprietas, la fila exterior de medidores debe acortarse, mientras que la fila interior se alarga. Esto le da al software Pixel una mayor deflexión absoluta para detectar y medir para activar la función.
