Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
Last year, the HTC-built Pixel XL showed us a novel way to remove an adhered battery—a perforated outer label let you pull the battery out of its shell, then easily peel off the rest of the label. This year, it seems LG's industrial design doesn't include any provisions for easily removing the battery. (RIP, ye olde LG.) This battery holds 13.6 Wh (3520 mAh at 3.85 V), slightly more than last year's 13.28 Wh.
  • Last year, the HTC-built Pixel XL showed us a novel way to remove an adhered battery—a perforated outer label let you pull the battery out of its shell, then easily peel off the rest of the label.
  • This year, it seems LG's industrial design doesn't include any provisions for easily removing the battery. (RIP, ye olde LG.)
  • This battery holds 13.6 Wh (3520 mAh at 3.85 V), slightly more than last year's 13.28 Wh.
  • That's roughly on-par with the 13.48 Wh power pack in Samsung's Galaxy S8+, and considerably more than the 10.28 Wh the iPhone 8 Plus manages to get away with.
El año pasado, el Pixel XL construido en HTC nos mostró una nueva forma de quitar una batería adherida de una etiqueta externa perforada, para que pueda desprenderse fácilmente del resto de la etiqueta
Este año, parece que el diseño industrial de LG no incluye ninguna disposición para extraer fácilmente la batería. (QEPD tu viejo LG.)
Esta batería contiene 13.6 Wh (3520 mAh a 3.85 V), un poco más que el 13.28 Wh del año pasado.
Aproximadamente a la par con el paquete de energía de 13.48 Wh en el Samsung Galaxy S8 +, y considerablemente más que los 10.28 Wh que eliPhone 8 Plus logra salirse con la suya.
