Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
The motherboard should lift right out of the case. To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard. To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard.
Motherboard Removal, continued.
  • The motherboard should lift right out of the case.
  • To remove the fan, unscrew the two Phillips head screws holding it in. It can then be unplugged from the motherboard.
La placa base debe levantarse directamente de la caja.
Para quitar el ventilador, desatornille los dos tornillos de cabeza Phillips que lo sujetan. Luego, puede desenchufarlo de la placa base.
