Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
The motherboard is held in with two black Phillips head screws, located on the left hand side. Be sure to unplug the antenna cables from the wireless card before removing the motherboard. Grasp the ethernet port, and lift the board out of the case.
Motherboard Removal
  • The motherboard is held in with two black Phillips head screws, located on the left hand side.
  • Be sure to unplug the antenna cables from the wireless card before removing the motherboard.
  • Grasp the ethernet port, and lift the board out of the case.
La placa base se sujeta con dos tornillos de cabeza Phillips negros, ubicados en el lado izquierdo.
Asegúrese de desenchufar los cables de antena de la tarjeta inalámbrica antes de extraer la placa base.
Sujete el puerto de ethernet y levante la placa de la carcasa.
