Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 3
Remove the 4 silver screws that hold the hard drive in the bracket. The metal shield with thermal pad in the red box will come off: this comes in handy if you have a blade SSD installed, as it insulates it from the metal. Carefully slide the 2.5" HDD or SSD out of its case. Carefully slide the 2.5" HDD or SSD out of its case.
HDD Bracket Disassembly
  • Remove the 4 silver screws that hold the hard drive in the bracket. The metal shield with thermal pad in the red box will come off: this comes in handy if you have a blade SSD installed, as it insulates it from the metal.
  • Carefully slide the 2.5" HDD or SSD out of its case.
Retire los 4 tornillos plateados que sujetan el disco duro en el soporte. El protector de metal con almohadilla térmica en la caja roja saldrá: esto es útil si tienes una SSD de hoja instalada, ya que la aísla del metal.
Con cuidado, deslice la unidad de disco duro o SSD de 2.5 "fuera de su caja.
