Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay. Carefully unplug the cables from the motherboard, and set the bracket aside. In the last photo, the slot for a blade SSD is marked. This is where you would install the blade SSD, and use a screw to hold it in place.
Lid and HDD Bracket
  • Lift the door, and keep an eye on the cables that connect to the NUC's motherboard. These cables are the power and data cables for the 2.5" hard drive bay.
  • Carefully unplug the cables from the motherboard, and set the bracket aside.
  • In the last photo, the slot for a blade SSD is marked. This is where you would install the blade SSD, and use a screw to hold it in place.
Levanta la puerta y vigila los cables que se conectan a la placa base de la NUC. Estos cables son los cables de alimentación y de datos para el compartimiento para disco duro de 2.5 ".
Desenchufe con cuidado los cables de la placa base y coloque el soporte a un lado.
En la última foto, se marca la ranura para un disco SSD. Aquí es donde debería instalar la SSD de la cuchilla y usar un tornillo para mantenerla en su lugar.
