Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 9
The new power supply is rated for 12 V at 1.083 A. This is a modest bump up from the 0.917 A power supply in the Apple TV 4th Generation. Again taking a design lead from its older sibling, the Apple TV 4K eschews internal wiring between the power supply and logic board.
  • The new power supply is rated for 12 V at 1.083 A. This is a modest bump up from the 0.917 A power supply in the Apple TV 4th Generation.
  • Again taking a design lead from its older sibling, the Apple TV 4K eschews internal wiring between the power supply and logic board.
  • The use of conductive posts in lieu of wiring probably saves internal real estate, and it eliminates the possibility of pinched or bent wires during assembly.
  • NXP Semiconductor TEA1833LTS switch mode power supply controller
La nueva fuente de alimentación tiene una potencia nominal de 12 V a 1.083 A. Este es un aumento modesto de la fuente de alimentación 0.917 A en Apple TV 4th Generation.
Tomando nuevamente el liderazgo de diseño de su hermano mayor, el Apple TV 4K evita el cableado interno entre la fuente de alimentación y la placa lógica.
El uso de postes conductivos en lugar de cableado probablemente ahorre espacio interno, y elimina la posibilidad de cables doblados o doblados durante el ensamblaje.
[* black] The new power supply is rated for 12 V at 1.083 A. This is a modest bump up from the 0.917 A power supply in the [guide|49046|Apple TV 4th Generation|stepid=107487|new_window=true].
[* black] Again taking a design lead from its older sibling, the Apple TV 4K eschews internal wiring between the power supply and logic board.
[* icon_note] The use of conductive posts in lieu of wiring probably saves internal real estate, and it eliminates the possibility of pinched or bent wires during assembly.
[* red] NXP Semiconductor [link|https://www.nxp.com/products/power-management/ac-dc-solutions/ac-dc-controllers/greenchip-smps-control-ic:TEA1833LTS|TEA1833LTS] switch mode power supply controller
