Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 9
As our quest continues, we find some quirky cables and brackets! First out: a new Lightning port bracket that seems to reinforce the new peach-colored port and trap the Taptic engine. Up to now, we've gleefully plugged along with our Phillips screwdriver—but alas, all good things must come to an end. In removing this bracket, we encountered our first tri-point screw. Still, it's no match for our 64 Bit Driver Kit!
  • As our quest continues, we find some quirky cables and brackets!
  • First out: a new Lightning port bracket that seems to reinforce the new peach-colored port and trap the Taptic engine.
  • Up to now, we've gleefully plugged along with our Phillips screwdriver—but alas, all good things must come to an end. In removing this bracket, we encountered our first tri-point screw. Still, it's no match for our 64 Bit Driver Kit!
  • We suspect that the newly colored Lightning port could be made of a heat-transferring plastic to allow for safer fast-charging. (Or, it could just be color-matched to the chassis.)
  • Next: a strange interconnect/antenna cable over the speaker.
  • Finally: the Taptic Engine nestled in a series of tiny fiddly connectors.
¡Mientras continuamos nuestra expedición, encontramos unos cables y soportes extravagantes!
Lo primero que retiramos: un nuevo soporte del puerto Lightning que parece reforzar el nuevo puerto de color durazno y atrapa el motor Táptico.
Hasta ahora, hemos estado usando nuestro destornillador Phillips — pero todas las cosas buenas tienen su fin. Al remover este soporte, nos encontramos con nuestro primer tornillo tri-punta. ¡Aún, no es ningún problema para nuestro 64 Bit Driver Kit!
Sospechamos que el nuevo puerto Lightning de color puede estar hecho de un plástico que transfiere calor para permitir una carga más rápida. (O, puede que sea para combinar con el color del chasis.)
Lo que sigue: un cable de antena/interconexión extraño sobre el altavoz.
Finalmente: el Motor Táptico entre una serie de conectores pequeños y complicados.
