Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 5
As we crack open this book display, we are greeted by the familiar display cable bracket. But instead of the cursed tri-point screws, we're happy to report that we're met with friendly Phillips #000 screws! We can't say that we will miss you, tri-points. We quickly decouple a few cables—the battery, display, and home button cables to be exact—and the display is free!
  • As we crack open this book display, we are greeted by the familiar display cable bracket. But instead of the cursed tri-point screws, we're happy to report that we're met with friendly Phillips #000 screws!
  • We can't say that we will miss you, tri-points.
  • We quickly decouple a few cables—the battery, display, and home button cables to be exact—and the display is free!
  • We note a lack of gaskets on the display's pentalobe tabs, which was previously seen in the iPhone 7.
  • However, both the iPhone 7 and iPhone 8 have an IP67 water resistance rating. How are the floodgates still closed!?
Mientras abrimos esta pantalla, nos da la bienvenida por el soporte del cable de la pantalla familiar. Pero en vez de los malditos tornillos tri-punta, nos pone felices de informar que nos encontramos con unos amigables tornillos Philips #000!
No podemos decir que los vamos a extrañar, tornillos de tri-punta.
Rápidamente separamos unos cables — los cables de la batería, la pantalla, y del botón de inicio para ser exacto— y la pantalla está libre!
Notamos una escasez de tapas en las lengüetas pentalobe de la pantalla, lo que se veia anteriormente en el iPhone 7.
Aun así, ambos el iPhone 7 y el iPhone 8 tienen una clasificación de resistencia al agua IP67. ¿Cómo es que las compuertas aun están cerradas?
