Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 19 guías que incluyan este paso.
Inglés
Español
Paso 4
Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket. Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board. Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
  • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
  • Pry only under the hinged retaining flap, not the socket itself, or you may break it off the board.
  • Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
Insertar traducción aquí
[* black] Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
[* icon_caution] Pry only under the hinged retaining flap, '''not''' the socket itself, or you may break it off the board.
[* black] Use the flat end of a spudger to gently back the keyboard ribbon cable out of its socket by pushing first at one side, then the other.
