Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 41 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched. Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. During reassembly, connect this end first as it does not flex.
  • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
  • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
  • During reassembly, connect this end first as it does not flex.
  • In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
  • Remove the I/O Board cable from the MacBook Pro.
Usando el extremo plano de un spudger, levanta el conector de la tarjeta de E / S hacia afuera de su zócalo en la placa lógica. Al volver a armar, conecta este extremo primero ya que no es flexible.
De forma similar, retira el conector de la placa de E / S de su zócalo en la placa de E / S.
Retira el cable de la placa de E / S de la MacBook Pro.
-[* black] Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
+[* icon_note] If your I/O Board cable's connectors have [link|https://guide-images.cdn.ifixit.com/igi/NcprwYqAITaNGRVg.full|notches in the padding], you will need to ***release a locking lever underneath the notch*** in order to remove the cable. If this is the case, ***don't pry up on the connector until the levers are unlatched***.
+[* black] Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
+ [* icon_reminder] During reassembly, connect this end first as it does not flex.
[* black] In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
[* black] Remove the I/O Board cable from the MacBook Pro.
