Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
If you are having trouble desoldering here are the two things you can do to solve. You can use a screw driver to open the resistors and then remove them from the board allowing access to the ground pins Now using snips you can cut the pins and then use a soldering iron to both sides and remove the cut pin gently with pliers
Troubleshooting
  • If you are having trouble desoldering here are the two things you can do to solve.
  • You can use a screw driver to open the resistors and then remove them from the board allowing access to the ground pins
  • Now using snips you can cut the pins and then use a soldering iron to both sides and remove the cut pin gently with pliers
Insertar traducción aquí
