Saltar al contenido principal
Inglés
Español
Paso 13
The connectors removed in the next few steps slide onto long pins attached to the logic board. Be sure to only pull them straight up from the logic board to avoid bending the pins.
  • The connectors removed in the next few steps slide onto long pins attached to the logic board. Be sure to only pull them straight up from the logic board to avoid bending the pins.
  • If you do bend the pins during removal, use the connectors as a guide to bend them back straight.
  • Use the tip of a spudger to lift the speaker cable connector from its lower edge straight up off the logic board.
Insertar traducción aquí
