Saltar al contenido principal
Inglés
Español
Paso 10
Remove the single 8 mm brass Phillips screw securing the inverter to the logic board. Lift the inverter straight up off the pins on the logic board.
  • Remove the single 8 mm brass Phillips screw securing the inverter to the logic board.
  • Lift the inverter straight up off the pins on the logic board.
  • Be sure to lift the inverter straight up off the logic board, as the connector pins are very long and easily bent. If the pins bend during removal, use the connector on the inverter as a guide to bend them straight.
Insertar traducción aquí
