Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 40 guías que incluyen este paso.
Inglés
Español
Paso 2
Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board. Pull the AirPort card parallel out of its connector on the logic board to remove it.
  • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
  • Pull the AirPort card parallel out of its connector on the logic board to remove it.
Sujeta los lados delgados de la tarjeta AirPort y tira paralelo a la placa lógica, retirando la tarjeta AirPort de la MacBook Pro.
-[* black] Grasp the thin sides of the AirPort card and pull parallel to the logic board, removing the AirPort card from the MacBook Pro.
+[* black] Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
+[* black] Pull the AirPort card parallel out of its connector on the logic board to remove it.
