Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 5 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 2
Paso 2
Use tweezers to lift the USB-C port just over the hinge screws. Slide the port out and up over the display hinge to remove it. There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
  • Use tweezers to lift the USB-C port just over the hinge screws.
  • Slide the port out and up over the display hinge to remove it.
  • There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
Insertar traducción aquí
