Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 9
In the following steps, you will be separating the home button gasket from the iPad's front panel. This gasket is extremely delicate and can tear easily. If the gasket does not separate easily from the front panel, reapply heat using the iOpener before continuing. Use the pointed end of a spudger to gently pry the Home Button assembly up from the display. Use the pointed end of a spudger to gently pry the Home Button assembly up from the display.
  • In the following steps, you will be separating the home button gasket from the iPad's front panel. This gasket is extremely delicate and can tear easily. If the gasket does not separate easily from the front panel, reapply heat using the iOpener before continuing.
  • Use the pointed end of a spudger to gently pry the Home Button assembly up from the display.
En los siguientes pasos, separarás la junta del botón de inicio del panel frontal del iPad. Esta junta es extremadamente delicada y se puede rasgar con facilidad. Si la junta no se separa fácilmente del panel frontal, aplica de nuevo calor usando el iOpener antes de continuar.
Usa la punta afilada de un spudger para separar suavemente el ensamblaje del botón de inicio de la pantalla.
