Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
Remove the Home Button bracket and peel up the tape connected to it. During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it Scrape off as much of the old adhesive residue from the bracket as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
  • Remove the Home Button bracket and peel up the tape connected to it.
  • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it
  • Scrape off as much of the old adhesive residue from the bracket as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
  • Secure the bracket with hot-melt glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
Insertar traducción aquí
