Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 17 guías que incluyan este paso.
Inglés
Español
Paso 5
Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case. Do not pull too hard or you may shatter the glass. Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  • Firmly pull up on the suction cup to to create a small gap between the front panel and the rear case.
  • Do not pull too hard or you may shatter the glass.
  • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
Insertar traducción aquí
