Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 7
Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display. Attach a suction cup to the upper right corner of the front glass panel. Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
  • Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display.
  • Attach a suction cup to the upper right corner of the front glass panel.
  • Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
  • Continue working along the right edge of the front display glass until it is separated from the display.
Insertar traducción aquí
