Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 11 guías que incluyan este paso.
Inglés
Español
Paso 4
Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.  For late-2011 models check out the other picture because the connector location is in a totally different location. Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing.  For late-2011 models check out the other picture because the connector location is in a totally different location.
  • Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing. For late-2011 models check out the other picture because the connector location is in a totally different location.
Insertar traducción aquí
