Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Note that the CPU will most likely remain stuck to the underside of the heat sink as it's lifted out. Take care not to damage it. Lift and remove the heat sink assembly from the logic board.
  • Note that the CPU will most likely remain stuck to the underside of the heat sink as it's lifted out. Take care not to damage it.
  • Lift and remove the heat sink assembly from the logic board.
Nota que la CPU puede quedar pegada debajo del disipador de calor cuando lo levantas. Ten cuidado de no dañarla.
Levanta y remueve el conjunto del disipador de calor de la placa lógica.
