Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 16
use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from  connector. be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one. first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
removing LCD cable
  • use the tip of a spudger or a tiny flathead screwdriver to push out the LCD cable from connector.
  • be very very very carefull , if you tear tis cable or damage it , you will have to buy a new one.
  • first lift the cable metal connector upwards ( push it out) , very gently, then the other side untill you can remove the cable.
Insertar traducción aquí
