Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Traduciendo paso 1
Paso 1
Remove the 6 outer screws on the underside of the laptop.
  • Remove the 6 outer screws on the underside of the laptop.
  • Open the battery compartment and remove the 7 visible screws.
  • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
  • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
  • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
  • Reassemble the laptop by following these steps in reverse.
  • The monitor should work when powered on again.
Insertar traducción aquí
