Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Traduciendo paso 17
Paso 17
A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part. The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly. The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
  • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
  • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
Una junta de goma en la parte inferior del conector Lightning protege tu iPhone contra la entrada de líquido y polvo. Si estás instalando un ensamblaje nuevo de conector Lightning, es posible que tengas que remover con cuidado y transferir la junta a la parte nueva.
El parche pequeño de adhesivo en la parte inferior de cada micrófono también protege tu iPhone contra la entrada de líquido y polvo. Para mejores resultados, reemplaza los dos parches de adhesivo antes de instalar tu ensamblaje de conector Lightning.
