Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 15
Slide your pick across the width of the iPhone to separate all the remaining strands of the flex cable from the rear case. Be very careful not to damage the battery in the process. A punctured battery can leak dangerous chemicals and/or catch fire. Be very careful not to damage the battery in the process. A punctured battery can leak dangerous chemicals and/or catch fire.
  • Slide your pick across the width of the iPhone to separate all the remaining strands of the flex cable from the rear case.
  • Be very careful not to damage the battery in the process. A punctured battery can leak dangerous chemicals and/or catch fire.
Desliza la púa por el ancho del iPhone para separar todas las hebras del cable flexible de la caja trasera.
Ten cuidado de no dañar la batería durante el proceso. Una batería perforada puede perder sustancias químicas peligrosas y/o prenderse fuego.
